humax Digitalreceiver Satellitenreceiver  IRCI-5400
Serverzeit: 14 5 2026  16:23:22      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
Digitalreceiver humax IRCI-5400
BID = 170652
mnadeem
Hersteller : humax
Gerätetyp : IRCI-5400
Chassis : smps
Hi
1 --- I have a problem that the receiver is not going on , found that first the ZD3 30v is dead, replaced , but then found the resistance R2 180kohm is blown out replace , still having same problem , ? .. what is the voltage on pin no 3(V)of ic ILO380R ,,, also changed all kinds of capacitors in PSU also critical resistance 100ohm R21 ..the receiver is chaked with other supply is ok .
2 ---- i have other receiver also humax F1 vaci , can not update with com rs232 and also taking too much time to on saying no signal ,, no voltage 13/18 , but after a wile coming back but only 18v on h , what could it be .
thanks waiting for your reply and advise
BID = 170695
mnadeem
Hi
My german is not too good ,but i can understand , if you write me something ..
So.. Can it be that TP1 is also dead or open , second one of my freinds said that i must also changed the cap C24 and C5 what is the value of ZD2
BID = 170779
Satfan123
Sat- und DBox-Spezialist
BID = 171051
mnadeem
Hi dir
Thanks for info ,, but i have the manual , I also changed all capicitors , also cheked ZD2 , bring me nothing the resistance R4 68ohm is ok with D6 working properly , ?
R1 47kohm also ok
BID = 171182
Satfan123
try a new PSU
cost @ ebay 20-29€
BID = 173644
mnadeem
HI
thanks any way
I have changed the capacitors no 9 and the haupt ic transistors 1lo380r and every thing ok , second ebay is high cost ,, i have found no artical that will bring upto 20 euro
© x sparkkelsputz        Besucher : 191979777   Heute : 15719    Gestern : 23007    Online : 511        14.5.2026    16:23
